Trouble automating winscp.com with Public Key
Mike250
Sydney, Australia
Hi there,
I am connecting to a client SFTP via shared Public Key (*.ppk) which I am successfully performing via the current WinScp.exe and Winscp.com. I have verified connectivity by putting and getting files both in the GUI and command line.
What I can't seem to do is automate the put of files from the command line. If I perform the following steps, one by one, at the command line, I am successful:
cd \program files (x86)\winscp\
winscp.com /command "open myuser@files.myclient.net" /privatekey=C:\Export\Scripts\20130620.ppk
put C:\Export\Archive\*.zip upload/
close
So, I created a batch file to perform this task, which connects and authenticates to the SFTP site just fine, but it does not perform the put. I have the winscp> prompt but nothing after that. See the connection log below.
Searching for host...
Connecting to host...
Authenticating...
Using username "myuser".
Authenticating with public key "20130620".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] myuser@files.myclient.net
winscp>
It just sits there. If I now manually enter put C:\Export\NoniB\Archive\*.zip upload/ the file will upload. I can't seem to get it to perform automatically. Any thoughts? Thank you in advance.
Mike250
Sydney, Australia
Additionally
Let me add, I have also tried this approach.
sftp.bat
winscp.com scp://myuser@files.myclient.net /privatekey=C:\Export\Scripts\20130620.ppk /script=c:\export\scripts\sftp.txt
sftp.txt
option batch abort
Same problem. Connects, authenticates, Active session - but no put. Awaiting at the prompt winscp>.
Authenticating...
Authenticated.
Session started.
winscp>
A bit baffled here, and have been digging through FAQ. I thank you kindly for any assistance.
Re: Additionally
Your second approach was close. Though you should see following message as a very first line of an output (providing you are using a recent version of WinSCP):
Automatic actions are disabled when URL address is provided on command-line.
You should do this:
winscp.com /script=c:\export\scripts\sftp.txt /log=c:\export\scripts\sftp.log
sftp.txt:
option batch abort
open scp://myuser@files.myclient.net -privatekey=C:\Export\Scripts\20130620.ppk
See here for details:
https://winscp.net/eng/docs/guide_automation
Note that I've added a /log=. If you still cannot make this work, please attach the log (c:\export\scripts\sftp.log).
BalajiKK
Re: Additionally
Hi
I am new to WinSCP/SFTP and I am struggling to automate the file transfer. The issue I have is that on top of Public Key (*.ppk), I have passphrase to use to establish the connection. Can someone please advise where to put the passphrase in these codes?
sftp.bat:
sftp.txt:
option batch abort
put C:\Export\Archive\*.csv
Balaji
You should do this:
sftp.txt:
option batch abort
Re: Additionally
There's -passphrase= switch:
https://winscp.net/eng/docs/scriptcommand_open#passphrase
See also https://winscp.net/eng/docs/faq_passphrase#automating
