Symbolic Links not working for DotNet GetFiles in FTP
jmcclosk
Philadelphia, PA Area
We are using symbolic links in Unix (AIX) to reference files and paths to do FTP protocol transfers. I am using the DotNet components, GetFiles method, WinSCP version 5.2.1 and a few older versions (5.1.4, etc.). I am getting the error "Real path and requested remote path do not match". Is this a bug? I have used other FTP products and we never had this type of issue with not supporting symbolic links for simple FTP GET or PUT functions.
When I change the remove folder to use the physical path, it works fine. So I know this issue is isolated to using the symbolic links on the remote host. I reviewed the Transfer Options, Session Options and WinSCP.INI settings but could not find any way to suppress this edit.
Please advise if I can turn this "edit" off or how I might proceed to get this fixed.
I have attached the log file output from this issue.
Thank You!
Joseph McCloskey
Re: Symbolic Links not working for DotNet GetFiles in FTP
Normally, when you do cd /path/symlink, you actually end in /path/symlink, not in /symlink_target. While with your server, you actually end in /symlink_target. WinSCP cannot handle that.
