PowerShell and XML Logging
JasonRkr
Sunny Southern California
Hello, Group!
How do I enable XML logging in a PowerShell script? I know there must be a simple way to do this, but I'm just not seeing it.
Also, before pointing me to the documentation, please understand I've been all over the WinSCP site and have Googled for it.
Thank you,
Jason
Re: PowerShell and XML Logging
How are you running WinSCP from your PowerShell script?
If you are using a WinSCP .NET assembly, it automatically turns on XML logging, as it uses the log to retrieve results. You can tell (or alter) a location of the log using Session.XmlLogPath. Though note that the assembly removes the log, once you call Session.Dispose. Anyway, if you are using the assembly, what do you need the XML log for? You get all the information from the assembly methods. That's actually a whole point of the assembly, to spare you from parsing the XML log.
