error when sending files through a http proxy
pfaff.thomas
Schiltach / Germany
Dear Forum users
Our Network is behind a http proxy
I have problems with some ftp servers when trying to send files.
The error does not appear on all target ftp servers, only at some of them
error message:
Error retrieving server address, cannot test if address is routable
the file will be transfered onlypartial, not the complete file.
The file is a csv file, change transfer mode from binary to asci or counterwise does not lead to success.
When I send the file via Filezilla, it works
kind regards
Thomas Pfaff
Re: error when sending files through a http proxy
Re: logfile attached
Strange thing is that you are able to transfer directory listing. So I do not understand why it does not work for files. Can you try to transfer small text file (hundreds of bytes) using text/ascii transfer mode?
