Unattended Install - No Update check
mygwl
Belgium
Hi there,
I've an issue with unattended installation of WinSCP 5.1.5.
I use the cmd winscp515setup.exe /SAVEINF="conf.inf" to generate a configuration file.
During the manual setup process, I disable auto updates :
Then I use the following script for silent installation :
"%~dp0winscp515setup.exe"  /VERYSILENT /NORESTART /LOADINF="%~dp0conf.inf" /NOCANDY /LOG="C:\install\Logs\winscp.txt"
The program is deployed to end users with Miscrofot SCCM 2007.
When I check the settings on users computers, the auto update setting is not disabled :
I checked in the registry, in noticed that there are keys related to updates settings in [HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration\Interface\Updates]
but I don't get how to set the value of the keys to disable autou pdates.
How can I fix that ?
How can I disable updates check, and check for beta version for all users when installing ?
Thanks in advance,
Yours faithfully, mygwl
Re: Unattended Install - No Update check
Thanks for your post.
This issue is being tracked already:
https://winscp.net/tracker/758
Meanwhile, you can turn off the update check by setting following registry key:
"Period"=dword:00000000
Kreezer
Sorry, but HKEY_CURRENT_USER isn't for all users.
You have to change the program to read HKEY_LOCAL_MACHINE, so it's global for all users.
You can set a default for all users this way:
[HKEY_LOCAL_MACHINE\SOFTWARE\Martin Prikryl\WinSCP 2]
"DefaultUpdatesPeriod"=dword:00000000
Harry_2440
Update check not disabled
when i add this reg key the auto updates are not chaning to NEVER.My environment is Win 10
Re: Update check not disabled
Note that DefaultUpdatesPeriod sets the default value. If the local account already has its own setting, changing the default won't override it.
lefefe
It´s not quite clear for me ... the default value leaves "display information about update on startup" checked although "automatic check period" is set to never.
Do users get display information about updates or not?
If WinSCP never checks for updates, it won't have anything to display.
