Could not retrieve directory listing with keepuptodate
MIchaelFanning
Dear Sirs / Madams
I have been testing WinSCP (Ver 5.1.5 (build 3261))to see if this was the ultimate solution to keep two directories in sync. Testing was successful but when I move this to our production environment I run into trouble. It is more than likely due to the number of directories that this is watching (over 6500 in both the local and remote directories). The purpose of the sync is we are photographing vast amount of resort guests each day and using their RFID media apply this to the EXIF data of the image. when we process the photo's the subject gets their photo in their own directory which then needs to be FTP up to the web server where the guests can view their photo's. The process works excellently with the exception of the automated bit where we need to copy the files from the server processing the images to the web server.
As mentioned in test WinSCP works wonderfully well. As the image is process and saved to the guests directory (created by the processing application), WinSCP picks this change up and transfers the data to the web server. However in production, the keepuptodate process starts OK and states that it is watching 6500 directories, but as soon as a new jpg is added to a directory the process falls over (in both the GUI and command line interfaces).
Can you confirm that this is too much for WinSCP or is this possible and I just need to address my approach?
batch abort
confirm off
Connecting to 192.169.XX.XX
Connected with 192.168.XX.XX Waiting for welcome message...
Connected
Starting the session...
Reading remote directory...
Session started.
Active session: [1] dashimage@192.168.XX.XX
/var/www/dashboard/uploads/photos
d:\ftp
winscp> keepuptodate "d:\ftp" "/photos"
Watching for changes, press Ctrl-C to abort...
Scanning 'd:\ftp' for subdirectories...
Watching for changes in 6655 directories...
Change in 'd:\ftp\1307601' detected.
Error listing directory '/photos/1307601'.
Failed to change directory.
(A)bort, (R)etry, (S)kip: Abort
Kind Regards
Michael Fanning
michael.fanning@perisher.com.au
Re: Could not retrieve directory listing with keepuptodate
Please attach a full log file showing the problem (using the latest version of WinSCP). Ideally also log from your development environment, where it works ok.
MichaelFanning
Hi Martin
Thanks for your update. I have added three zip files for your perusal (for some reason it will only alow me to attach three). What I have done is attached the development script that was run and the log file produced. This works fine and the files on both local machine and the FTP server is keeptupto date. Again I cleared both directories when I commenced this test so everything was clean.
The second attachement has the script and log produced in the production environment. This now has over 7000 directories (growing quite fast). The script runs OK to kick it all off. However once it detects a change in the directory, the script fails. The log indicated that it could not retrieve the directory listing.
Based on that, I ran a new script (Third attachment) that ran the same connection Production environment parameters but just did a simple directory listing, change directories and again a directory listing to ensure that I was was in the correct directories at the start. This works OK too so I am not sure why the production script fails. Again I am assuming that the amount of directories it needs to keepuptodate is way too much.
My other line of thinking was to run the "/Synchronise" command (sorry /synchronize), but I need to modify the directory structure before I do this.
Any ideas?
Kindest Regards
Michael Fanning
Perisher
Description: Production. I decided to modify the script so that it performs a simple change directory and list files. Works OK.
Description: Production Script file and log. The script fail when trying to update indicating that it could not retrieve the directory.
Description: Development script file that was run and log that was produced. This works without any issues.
Key is this:
> 2013-07-19 09:24:05.916 CWD /photos/1307601/
< 2013-07-19 09:24:05.932 550 Failed to change directory.
Are you sure the path is /photos/1307601/? Maybe you wanted to use /var/www/dashboard/uploads/photos/1307601/?
