SynchronizeDirectories transfer speed limit
Is it possible to set the transfer speed limit for synchronizing directories using the .net assembly?
In the output it looks like it's running the synchronize scripting command, which has the -speed switch. Is it possible to add the switch to the command somehow, or is it not implemented?
Cheers
Cheers
