EtienneG
I use this version WinSCP 5.2.1 (running in Win XP, Win 7 and firewalls are disable) and Filezilla Server 0.9.41.
I have a problem with the synchronization of files, the messages appear randomly on GUI and scripting with Powershell (2 and 3):
"Timeout detected.
Connection accepted
Error listing directory"
Session parameters :
FTP with SSL/TLS Implicit encryption
Port 990
Passive mode
Synchronize parameters
Direction : Local
Mode : Synchronize files
Synchronize options : Delete files, Preview Changes
Comparison criteria : Modification time, File size
Transfer settings : Binary
Transfer runs with another FTP client and Filezilla Server as WinSCP and another FTP Server (CrushFTP)
The parameters of session can't be modified
Thanks for your answer
Re: Could not retrieve directory listing
Thanks. Can you please also provide a session log for a successful scenario?
Thanks. I did not find any clue yet. Do you have an access to server-side logs?
GermonE
The Filezilla server logs are identical to the file LogSession.
Sorry, I don't have more information to provide you.
