ForceBanners=DWORD:0000001 not working
I installed the lastest WinSCP build on a Windows XP system.
I implemented the ForceBanners fix as suggested on your site in the following registry key
HKLM\Software\Martin Prikryl\WinSCP 2
Users are still able to uncheck the box when the banner shows up.
Does having roaming profiles effect the way this fix works?
When I logged into the machine with my roaming profile account I noticed there was another entry in HKCurrentUser\Software\Martin Prikryl\WinSCP 2\ I took the liberty to apply the fix there but to no avail
Any insight to this will help me greatly
Thanks!!
Re: ForceBanners=DWORD:0000001 not working
Sorry, I've overlooked your post.
The ForceBanners works for me.
Please share exact export of the key.
It should look like:
[HKEY_LOCAL_MACHINE\SOFTWARE\Martin Prikryl\WinSCP 2]
"ForceBanners"=dword:00000001
Hi Martin,
I have place the exact key as you have written.
It seems to work when you don't have windows roaming profiles activate.
When you are on a network with Windows roaming profiles activated it tends to fail.
Yeah I asked myself that question as well. I would have thought once you placed the correct flags into HKLM it would automatically kick in.
I did notice, however, that systems with Roaming Windows adds another registry key in HKEY_CURRENT_USER\SOFTWARE\Martin Prikryl\WinSCP 2 where you have to put in the ForceBanners flags in too. I decided to try it out but that didn't work, I'm out of ideas?
WinSCP reads ForceBanners from HKEY_LOCAL_MACHINE only. Unless with Roaming profiles enabled, some redirections do occur behind the scenes.
Anyway, how do you set the ForceBanners in HKEY_LOCAL_MACHINE? (I do not know how Roaming profiles are administered). Can you see the value set in HKEY_LOCAL_MACHINE after you login with account that uses Roaming profiles?
Hi Martin,
Yes I do see the value I set in HKLM after logging in, but for whatever reason unknown to me it still allows me to check the box to disable the warning banner
Re: Same problem
samsonite wrote:
I too am having this issue on Windows Server 2008 R2 SP1
The same answer:
