Session.PutFiles - non recursive SFTP
John Thomas
Malaysia
I need to do an SFTP transfer which is non-recursive.
I tried using Filemasks but still not able to do a non-recursive transfer.
Currently all the files and subdirectories in the source location are transferred over. I need the sub directories to remain intact.
How do I proceed further?
Thanks a bunch!
HateCrew
Can't Upload without subdirectories
Hi All
We face the same issue by upload some files but without subdirectories.
var localPath = "C:\Temp\WinSCP\";
var ftpPath = "sftp.winscp.com/upload/test";
//var fileMask = $@"*.rck | */";
var fileMask = $@"*.* | */";
var transferResult = session.PutFiles(localPath, ftpPath, false, new TransferOptions() { OverwriteMode = OverwriteMode.Overwrite, TransferMode = TransferMode.Binary, FileMask = fileMask });
We have to upload all *.rck Files but without any subdirectories.
Tested with Version 5.19.6 without any success.
HateCrew
Re: Can't Upload without subdirectories
Hi Martin, as wished I attached a fresh new logfile.
  • session_anonym.txt (20.25 KB, Private file)
Ok, so you do not have a problem with subdirectories, right? The problem is that nothing is uploaded.
The logs file tells, what's wrong:
Selecting files using a path ending with slash is ambiguous. Remove the slash to select the folder. Append * mask to select all files in the folder.
See also https://winscp.net/eng/docs/library_session_putfiles#parameters
I assume you want:
var localPath = "C:\Temp\WinSCP\*";
var ftpPath = "sftp.winscp.com/upload/test/";
HateCrew
Hi Martin
We checked with your input without success.
The Folder in the root directory and all files in it with the same ending are uploaded.
We only want to upload the root directory with the topdirectory files.
Without the Folder and without files in the subfolders, also not if they match filepattern.
Thanks for help.
HateCrew
As requested
I also added the logging.txt from WinSCP
  • session.txt (486.43 KB, Private file)
  • logging.txt (858.18 KB, Private file)
Where's the | */? I do not see you using it in the log. The file mask is only *.rck. You have to use both the | */ and the correct paths.
HateCrew
You are totally right, we missed to add it for testing again.
We also got it working now with following changes:
  • localfilepath has to end with \*
  • ftp path has to end with /
  • filepattern is .rck | */
Thanks for the help, don't know why it not worked earlier, because we had this as testcase.
