WinSCP not syncing
highwingers
WinSCP not syncing
I am trying to sync my Local directory(Windows 2008 server) with my Remote FTP Directory(WD MyLive NAS)....my log shows I was able to connect to remote directory and all is fine....however nothing is getting transfered...below is the LOG.
. 2013-06-17 15:43:37.272 --------------------------------------------------------------------------
. 2013-06-17 15:43:37.272 WinSCP Version 5.1.5 (Build 3261) (OS 6.1.7601 Service Pack 1)
. 2013-06-17 15:43:37.272 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2013-06-17 15:43:37.272 Local account: 62-64-77-117\sk1
. 2013-06-17 15:43:37.272 Working directory: C:\Program Files (x86)\WinSCP
. 2013-06-17 15:43:37.272 Process ID: 2952
. 2013-06-17 15:43:37.272 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe" /console=515 /consoleinstance=_10008_723 "/console" "/script=C:\WinScp-Backups-Script\script.txt" "/log=C:\WinScp-Backups-Script\log.log"
. 2013-06-17 15:43:37.272 Time zone: Current: GMT-4, Standard: GMT-5, DST: GMT-4, DST Start: 3/10/2013, DST End: 11/3/2013
. 2013-06-17 15:43:37.272 Login time: Monday, June 17, 2013 3:43:37 PM
. 2013-06-17 15:43:37.272 Session name: sk1@rdp.kh1zon.com (Modified stored session)
. 2013-06-17 15:43:37.272 Host name: rdp.kh1zon.com (Port: 21)
. 2013-06-17 15:43:37.272 User name: sk1 (Password: Yes, Key file: No)
. 2013-06-17 15:43:37.272 Tunnel: No
. 2013-06-17 15:43:37.272 Transfer Protocol: FTP
. 2013-06-17 15:43:37.272 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2013-06-17 15:43:37.272 Proxy: none
. 2013-06-17 15:43:37.272 FTP: FTPS: None; Passive: Yes [Force IP: A]
. 2013-06-17 15:43:37.272 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2013-06-17 15:43:37.272 Cache directory changes: Yes, Permanent: Yes
. 2013-06-17 15:43:37.272 DST mode: 1; Timezone offset: 0h 0m
. 2013-06-17 15:43:37.287 Connecting to rdp.kh1zon.com ...
. 2013-06-17 15:43:37.365 Connected with rdp.kh1zon.com. Waiting for welcome message...
< 2013-06-17 15:43:37.443 220 "Welcome to MyBookLive"
> 2013-06-17 15:43:37.443 USER sk1
< 2013-06-17 15:43:37.521 331 Please specify the password.
> 2013-06-17 15:43:37.521 PASS *********
< 2013-06-17 15:43:37.615 230 Login successful.
> 2013-06-17 15:43:37.615 SYST
< 2013-06-17 15:43:37.677 215 UNIX Type: L8
> 2013-06-17 15:43:37.677 FEAT
< 2013-06-17 15:43:37.755 211-Features:
< 2013-06-17 15:43:37.755 EPRT
< 2013-06-17 15:43:37.755 EPSV
< 2013-06-17 15:43:37.755 MDTM
< 2013-06-17 15:43:37.755 PASV
< 2013-06-17 15:43:37.833 REST STREAM
< 2013-06-17 15:43:37.833 SIZE
< 2013-06-17 15:43:37.833 TVFS
< 2013-06-17 15:43:37.833 UTF8
< 2013-06-17 15:43:37.833 211 End
> 2013-06-17 15:43:37.833 OPTS UTF8 ON
< 2013-06-17 15:43:37.896 200 Always in UTF8 mode.
. 2013-06-17 15:43:37.896 Connected
. 2013-06-17 15:43:37.896 --------------------------------------------------------------------------
. 2013-06-17 15:43:37.896 Using FTP protocol.
. 2013-06-17 15:43:37.896 Doing startup conversation with host.
> 2013-06-17 15:43:37.896 PWD
< 2013-06-17 15:43:38.005 257 "/"
. 2013-06-17 15:43:38.005 Getting current directory name.
. 2013-06-17 15:43:38.020 Startup conversation with host finished.
< 2013-06-17 15:43:38.020 Script: Active session: [1] sk1@rdp.kh1zon.com
> 2013-06-17 15:43:38.020 Script: synchronize local C:\Server\benji /Backups/WinScp/Benji
< 2013-06-17 15:43:38.020 Script: Comparing...
. 2013-06-17 15:43:38.020 Collecting synchronization list for local directory 'C:\Server\benji' and remote directory '/Backups/WinScp/Benji', mode = Local, params = 0x2 (NoConfirmation)
. 2013-06-17 15:43:38.020 Local file 'C:\Server\benji\.' [2013-04-15T04:40:54.731Z] [0] excluded from synchronization
. 2013-06-17 15:43:38.020 Local file 'C:\Server\benji\..' [2013-04-15T04:40:54.731Z] [0] excluded from synchronization
. 2013-06-17 15:43:38.020 Local file 'C:\Server\benji\giggledots.com' [2012-12-10T18:52:27.124Z] [0] included to synchronization
. 2013-06-17 15:43:38.020 Local file 'C:\Server\benji\manager.giggledots.com' [2012-04-18T03:53:41.954Z] [0] included to synchronization
. 2013-06-17 15:43:38.020 Local file 'C:\Server\benji\manager.modernlittles.com' [2013-04-15T05:02:48.973Z] [0] included to synchronization
. 2013-06-17 15:43:38.020 Local file 'C:\Server\benji\modernlittles.com' [2013-06-07T03:01:46.141Z] [0] included to synchronization
. 2013-06-17 15:43:38.020 Retrieving directory listing...
> 2013-06-17 15:43:38.020 CWD /Backups/WinScp/Benji/
< 2013-06-17 15:43:38.083 250 Directory successfully changed.
> 2013-06-17 15:43:38.083 PWD
< 2013-06-17 15:43:38.161 257 "/Backups/WinScp/Benji"
> 2013-06-17 15:43:38.161 TYPE A
< 2013-06-17 15:43:38.239 200 Switching to ASCII mode.
> 2013-06-17 15:43:38.239 PASV
< 2013-06-17 15:43:38.301 227 Entering Passive Mode (67,80,210,156,19,203).
> 2013-06-17 15:43:38.301 LIST -a
< 2013-06-17 15:43:38.457 150 Here comes the directory listing.
. 2013-06-17 15:43:38.457 drwxrwxr-x 2 ftp ftp 65536 Jun 17 14:45 .
. 2013-06-17 15:43:38.457 drwxrwxr-x 9 ftp ftp 65536 Jun 17 14:46 ..
< 2013-06-17 15:43:38.520 226 Directory send OK.
. 2013-06-17 15:43:38.520 Directory listing successful
. 2013-06-17 15:43:38.520 Retrieving directory listing...
> 2013-06-17 15:43:38.520 TYPE A
< 2013-06-17 15:43:38.598 200 Switching to ASCII mode.
> 2013-06-17 15:43:38.598 PASV
< 2013-06-17 15:43:38.676 227 Entering Passive Mode (67,80,210,156,19,168).
> 2013-06-17 15:43:38.676 LIST
< 2013-06-17 15:43:38.816 150 Here comes the directory listing.
. 2013-06-17 15:43:38.816 <Empty directory listing>
< 2013-06-17 15:43:38.894 226 Directory send OK.
. 2013-06-17 15:43:38.894 Directory listing successful
. 2013-06-17 15:43:38.894 ..;D;0;1899-12-30T04:00:00.000Z;"" [0];"" [0];---------;0
. 2013-06-17 15:43:38.894 Local file 'C:\Server\benji\giggledots.com' [2012-12-10T18:52:27.124Z] [0] is new
. 2013-06-17 15:43:38.894 Local file 'C:\Server\benji\manager.giggledots.com' [2012-04-18T03:53:41.954Z] [0] is new
. 2013-06-17 15:43:38.894 Local file 'C:\Server\benji\manager.modernlittles.com' [2013-04-15T05:02:48.973Z] [0] is new
. 2013-06-17 15:43:38.894 Local file 'C:\Server\benji\modernlittles.com' [2013-06-07T03:01:46.141Z] [0] is new
< 2013-06-17 15:43:38.894 Script: Synchronizing...
. 2013-06-17 15:43:38.894 Synchronizing local directory 'C:\Server\benji\' with remote directory '/Backups/WinScp/Benji/', params = 0x2 (NoConfirmation)
> 2013-06-17 15:43:38.894 Script: close
. 2013-06-17 15:43:38.894 Disconnected from server
Re: WinSCP not syncing
The log says that there are no files in the remote directory, hence nothing to synchronize:
Maybe you wanted to synchronize other way around (local=>remote)?
