SFTP on Win 7 64 bit, no go
Tony Thijs
Amsterdam
I tried to install winscp on Win 7 64 bit. It seems that WINSCP is not compatible. Is there a solution for this?
Kind regards,
Tony Thijs
Brogue2
I have WinSCP version 5.2.1 installed on Windows 7 (64 bit). No problems here connecting to and managing files on an SFTP server.
Can you describe your problem in greater detail? What exactly isn't working as you expected.
Re: SFTP on Win 7 64 bit, no go
WinSCP runs fine on Windows 7 64bit.
What makes you believe it's not compatible? Any error message?
