sync old file in monitoring with "keepuptodate "
st4rtx
hello
i use winscp for syn a folder betwin windows and linux but when a old file edited this file isnot sync on the remote server! how can i use "keepuptodate that sync oldfile
i use "keepuptodate with command line
please help me
Re: sync old file in monitoring with "keepuptodate "
