Using filemask with exclude and timestamp
Hi
I'm trying to use -filemask to download files since a certain timestamp, AND exclude sub directories.
On it's own, the timestamp works fine, but it downloads qualifying files in the sub directories too:
On its own, excluding sub directories also works fine:
However, when I attempt to combine the two, I get an error:
I tried wrapping the filemask in double double-quotes (per this link https://winscp.net/forum/viewtopic.php?t=12192) but got errors about changing directory (see below - earlier in the script I changed to the /Downloads folder without issue)
Any suggestions?
get -filemask="*.*>2013-5-29 07:11:00" *.* .\
get -filemask="*.*| */" *.* .\
get -filemask="*.*| */>2013-5-29 07:11:00" *.* .\ Mask is invalid near '>2013-5-29 07:11:00'
> 2013-05-29 11:37:19.740 Script: get -filemask=""*.*| */>2013-5-29 07:11:00"" *.* .\ . 2013-05-29 11:37:19.740 Retrieving directory listing... > 2013-05-29 11:37:19.740 CWD /Downloads/*/ < 2013-05-29 11:37:19.762 550 Can't change directory to /Downloads/*/: No such file or directory
Any suggestions?
