Read Registry values if WinSCP is installed
thpanos
Athens, Greece
I am developing an MS Access 2010 app in VBA
I am trying to check if WinSCP is installed on a machine.
As WinSCP.tlb is a reference to my project,
I am checking via VBA, if the file "%windir%\system32\winscp.tlb"
(or "%windir%\system64\winscp.tlb") exists
If not, I am registering COM assembly via code, with RegAsm.exe using:
%WINDIR%\Microsoft.NET\Framework\<version>\RegAsm.exe WinSCPnet.dll /codebase /tlb
Is it possible to read WinSCP registry key and value for that?
I can read registry keys and values in VBA
Re: Read Registry values if WinSCP is installed
Do you want to test, if WinSCP is installed or registered?
If registered, IMHO the best test, is to try to instantiate the WinSCP.Session class.
