GUI and WinSCP.com work, Powershell does not
maheller08
PA
The important part of the Powershell is this. The password has a $ in it. The session log and debug logs are attached and the logs from the GUI when it worked. Any help is greatly appreciated. Please let me know if more information is needed. WinSCP 5.1.4
Get this error from the script. "Connection has been unexpectedly closed. Server sent command exit status 0."
. 2013-05-14 16:09:06.800 Attempting keyboard-interactive authentication
. 2013-05-14 16:09:07.002 Prompt (6, SSH server: Password Authentication, Using keyboard-interactive authentication., xxxxxx's password:)
. 2013-05-14 16:09:07.002 Using stored password.
. 2013-05-14 16:09:08.999 Keyboard-interactive authentication failed
! 2013-05-14 16:09:08.999 Access denied
. 2013-05-14 16:09:08.999 Attempting keyboard-interactive authentication
. 2013-05-14 16:09:09.233 Prompt (6, SSH server: Password Authentication, Using keyboard-interactive authentication., xxxxxxx's password:)
. 2013-05-14 16:09:09.233 Disconnected: Unable to authenticate
try
# Load WinSCP .NET assembly
[Reflection.Assembly]::LoadFrom("WinSCP.dll") | Out-Null
# Setup session options
$sessionOptions.HostName = "xxxxx"
$sessionOptions.UserName = "xxxxx"
$sessionOptions.Password = "xxxxx"
$sessionOptions.SshHostKeyFingerprint = "ssh-rsa xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
$session.SessionLogPath = "seslog.txt"
$session.DebugLogPath = "deblog.txt"
try
# Connect
# Upload files
$transferOptions.TransferMode = [WinSCP.TransferMode]::Automatic
Re: GUI and WinSCP.com work, Powershell does not
I can see one difference. In GUI, you have "keyboard interactive" authentication disabled. As a consequence GUI is using password authentication, while .NET library is using keyboard interactive authentication.
Is it by purpose? I actually do not see, how this could cause your problem, but it's definitely worth trying.
See https://winscp.net/eng/docs/rawsettings
maheller08
PA
With the GUI I actually tried it with and without attempt keyboard interactive authentication enabled at it works both ways with the GUI. It appears that the remote server, which is not under my control, is not accepting the password from the Powershell script. I looked for, but could not find a way to disable keyboard interactive authentication with the .Net library. Is there a way to do that?
Thank you for your help.
Mark
maheller08
PA
Mark
No matter what raw settings I try for authentication the Powershell script will not authenticate. I resorted to creating a VB application. For what ever reason that works fine. It is a mystery to me.
Ok, I took a look on PowerShell string syntax, to find that dollar sign has special meaning, when inside souble-quotes, so you have to escape it. Are you aware of this?
Possibilities:
- use tick sign to escape it: "aaa`$bbb"
- using single quotes: 'aaa$bbb'
maheller08
PA
Possibilities:
I should have recogonized that fact, but it did not sink in. Thank you for the insight. The script now works great.
Thank you very much.
