JScript Fails Windows Server 2003
Ep3demic
I have had some problems setting up the enviroment on one of our servers running Windows Server 2003.
I have been following the guidelines on these sites (https://winscp.net/eng/docs/library_install)
<job>
<reference object="WinSCP.Session" />
<script language="JScript">
try
    // Setup session options
    var sessionOptions = WScript.CreateObject("WinSCP.SessionOptions");
    sessionOptions.Protocol = Protocol_Sftp;
    sessionOptions.HostName = "example.com";
    sessionOptions.UserName = "user";
    sessionOptions.Password = "mypassword";
    sessionOptions.SshHostKeyFingerprint = "ssh-rsa 1024 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx";
    var session = WScript.CreateObject("WinSCP.Session");
    try
        // Connect
        session.Open(sessionOptions);
        // Upload files
        var transferOptions = WScript.CreateObject("WinSCP.TransferOptions");
        transferOptions.TransferMode = TransferMode_Binary;
        var transferResult = session.PutFiles("d:\\toupload\\*", "/home/user/", false, transferOptions);
        // Throw on any error
        transferResult.Check();
        // Print results
        for (var enumerator = new Enumerator(transferResult.Transfers); !enumerator.atEnd(); enumerator.moveNext())
            WScript.Echo("Upload of " + enumerator.item().FileName + " succeeded");
    finally
        // Disconnect, clean up
        session.Dispose();
catch (e)
    WScript.Echo("Error: " + e.message);
    WScript.Quit(1);
</script>
</job>
It fails with this error message:
Could not locate automation class named "WinSCP.SessionOptions".
Running from CMD with
cscript test.wsf
WinSCP is installed under C:\Apps\WinSCP. I have the .NET Assembly dll WinSCPnet.dll placed under the same folder.
The script is running from C:\Scripts. I have .NET Framework 3.5 Installed on the server.
Other sample scripts are failing with the WshShell.exec object as source. I can run simple JavaScript code, but when i include your .NET Assembly to the code it fails.
What am I missing here?
Re: JScript Fails Windows Server 2003
Can you provide more details on this? What scripts? What error?
Ep3demic
When I try to run the above code I get this error message:
When I try to run the above code embedded in SWF I get this error message:
Windows Script Host
Error: Could not locate automation class named "WinSCP.SessionOptions".
OK
