Overwrite prompt
Linda Kaioh
Overwrite prompt
Hi!
Currently overwrite prompt in WinSCP looks like this:
I found it not so convenient and spent few seconds every time to decide right button (usually - "Yes to all").
I think it will be better to redesign this window like this:
It will group similar buttons and make layout more logical. Some time ago FAR Manager used layout like this and I think WinSCP should too ^^
Thanks!
Linda Kaioh
Thanks for reply.
1) In Windows XP, all actions are available via separate buttons.
I have Windows XP T_T That's why I didn't notice this change in latest beta.
Under Windows 7 it looks nice not so convenient. Instead of all these pull-down menus you can use single checkbox "Use this action for all files" or something like this. Current versions of FAR Manager use this approach. And it's more keyboard friendly.
But there are lot of other minor options, that this would not take care of, like Newer Only, Append, Resume and New Name. Keyboard accelerators still work as before.
