Lock session can not be close by other user
Mahdi Bashiri
Hi
I'm using winscp to keeping remote directory up to date for two ftp servers, but other users who access to this server by mistake close the session and remote site does not receive new created file until doing this procedure, I would like to know is there any way to lock this session and when other users by mistake want to close ask them password and can not be close
Regards,
Mahdi bashiri
Re: Lock session can not be close by other user
What "session" so you mean? Desktop session of Windows machine that runs WinSCP?
Mahdi Bashiri
Lock winscp session
Dear
I mean is to lock winscp session so other users can not close my open winscp session and ask him/her to close by password.
Regards,
Mahdi
Re: Lock winscp session
Ok, so you want to leave you computer unlocked with WinSCP running and you want to prevent other users of your computer to tamper with WinSCP, right?
It's not possible. You should set up separate accounts on your machine.
Mahdi Bashiri
run winscp as service
hi
is there a way to run winscp keepuptodate script as service while I can not prevent user from can not closing my winscp running program
I need winscp keepuptodate script and how can I use as windows service that start with windows staring and does not stop while windows shutting down.
Regards,
Mahdi Bashiri
Re: run winscp as service
WinSCP does not support this natively. You can definitely create such a service. But this is out of scope of this forum.
