Is there a way to force "manual resume"?
stephenjust
I am transferring files over FTP, and I want to force the equivalent of 'put -resume <source> <dest>' using the .NET assemblies to recover from connection errors, etc while transferring files in the order of 10GB in size. Is this possible to do or has it not been (or will not be) implemented yet?
Thank you!
Re: Is there a way to force "manual resume"?
That has not been implemented yet. WinSCP .NET assembly is open source, so it should be easy for you to add it.
stephenjust
You mean like this? (see attached) :wink:
You were right about it being an easy change :)
Thanks for the great software
(You can have the ~5 lines of code, this would be nice to see in an official release)
Description: Changed file
Akarius wrote:
Where can I find the source of the .NET Assembly?
It's included in source code package in 5.2.x and newer.
