Sync file/directory name changes
SKG990
Would be very helpful to be able to sync directory name changes instead of WinSCP thinking that this is a new directory and uploading its entire contents all over again, even though the contents are identical.
Re: Sync file/directory name changes
How would you make WinSCP find out that it is the same directorty, just renamed?
