Delete remote files older than
GTypeR
Hi. I've been trying to figure out if this is possible with WinSCP. However, I can't see if something like the -filemask switch is available for the rm command or if the synchronize command has a remote -delete switch, rather than a local one.
I'm basically trying to upload the latest file and then delete anything over 1 month old on the remote server.
I haven't got SSH access so I can't do it that way.
Re: Delete remote files older than
I've just thought, I may just delete the whole remote directory and just use a put command with the -filemask switch to upload the most recent files. I'll do this if there's no cleaner solution.
schultkl
USA
I see the following time constraints:
One of the following units must be used: Y (years), D (days), H (hours), N (minutes) or S (seconds).
Might a month constraint exist? Thank you.
Note: we can get close enough for our purposes using 182D instead of 6M...
Paccatore
Sorry but rm *<180D doesn't work, error "can't get files attribute" or something like "there are no file", what's the limit?
@Paccatore: There's no limit. The problem is likely elsewhere. Please attach a full session log file showing the problem (using the latest version of WinSCP).
