Connecting in Client Works, .Net Doesn't
rchamberlin
United States
I am able to make an SFTP connection using public/private keys to our server using the WinSCP client. However, trying to connect via the .Net assembly doesn't work and errors with:
Connection has been unexpectedly closed. Server sent command exit status 0
Here are my SessionOptions:
Protocol = Protocol.Sftp,
PortNumber = 22,
HostName = "servername",
UserName = "sftpuser",
SshHostKeyFingerprint = "ssh-rsa 1024 fc:e3:82:20:f1:6a:f2:a7:ef:ee:62:9a:48:e8:34:a7",
SshPrivateKeyPath = @"C:\temp\rsa-key-20130424_dvmsp006.ppk"
I couldn't find any documentation on whether I'm setting up my options correctly when doing this. Any help would be GREATLY appreciated!
Re: Connecting in Client Works, .Net Doesn't
Turn on session logging both in GUI and .NET (Session.SessionLogPath) and look for differences. If it does not help, please attach both logs here.
d4_david
Prague
PortNumber = 22,
Hi rchamberlin,
I do have same problem like you. Did you solve it somehow?
Thanks a lot.
