Error message from server: Not allowed to rename files
mr3316a
I'm trying to create a new file transfer process, and when I run the script I receive the following error message. Could someone help me intrepid what it is telling me, and how to go about fixing it?
/FCOE/GENLEDGE
Dr-xr-x--- 0 512 Apr 17 15:59:13 2013 ..
C:pudcharge20130416.dat | 703 KiB | 573.9 KiB/s | binary | 100%
Transfer was successfully finished, but temporary transfer file 'pudcharge201304
16.dat.filepart' could not be renamed to target file name 'pudcharge20130416.dat
'. If the problem persists, you may try to turn off transfer resume support.
Permission denied.
Error code: 3
Request code: 18
mr3316a
Re: Error message from server: Not allowed to rename files
Thanks Martin
I followed the directions and the file no longer is being passed with the .filepart extension. However the transfer is still not taking place. I'm now getting an error code of 4. I'm starting to think that it may be a permissions issue based on the rights setting of "xr-x---", what do you think?
Also what is an error code 4 mean?
mr3316a wrote:
Thanks Martin
Please share complete error message. Or even better a complete session log file.
Otherwise I can only point you to:
https://winscp.net/eng/docs/sftp_codes
mr3316a
Martin the session is as follows:
Copying 1 files/directories to remote directory "/FCOE/GENLEDGE/"
PrTime: Yes; PrRO: No; Rght: rw-rw-rw-; PrR: Yes (Yes); FnCs: N; RIC: 0100; Resume: N (102400); CalcS: Yes; Mask: *.*
TM: B; ClAr: No; CPS: 0; NewerOnly: No; InclM:
AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
File: "C:\Flash PUD Uploader\Reports\pudcharge20130416.dat"
Copying "C:\Flash PUD Uploader\Reports\pudcharge20130416.dat" to remote directory started.
Binary transfer mode selected.
Opening remote file.
Type: SSH_FXP_OPEN, Size: 61, Number: 9475
Type: SSH_FXP_STATUS, Size: 40, Number: 9220
Discarding reserved response
Type: SSH_FXP_STATUS, Size: 66, Number: 9475
Status code: 4, Message: 9475, Server: Sftp daemon generated exception in initPut call. , Language:
Type: SSH_FXP_LSTAT, Size: 45, Number: 9735
Type: SSH_FXP_STATUS, Size: 78, Number: 9735
Status code: 2, Message: 9735, Server: /FCOE/GENLEDGE/pudcharge20130416.dat is not a valid file path, Language:
(ETerminal) General failure (server should provide error description).
Error code: 4
Error message from server: Sftp daemon generated exception in initPut call.
Request code: 3
Asking user:
Cannot create remote file '/FCOE/GENLEDGE/pudcharge20130416.dat'. ("General failure (server should provide error description).
Error code: 4
Request code: 3")
(EScpSkipFile) Cannot create remote file '/FCOE/GENLEDGE/pudcharge20130416.dat'.
Error code: 4
Request code: 3
Listing directory "/FCOE/GENLEDGE".
Type: SSH_FXP_OPENDIR, Size: 23, Number: 9995
Type: SSH_FXP_HANDLE, Size: 23, Number: 9995
Type: SSH_FXP_READDIR, Size: 23, Number: 10252
Type: SSH_FXP_STATUS, Size: 35, Number: 10252
Status code: 1
Listing file "/FCOE/GENLEDGE/..".
Type: SSH_FXP_LSTAT, Size: 26, Number: 10503
Type: SSH_FXP_ATTRS, Size: 37, Number: 10503
..;D;512;2013-04-30T16:02:10.000Z;"" [2];"" [2];r-xr-x---;0
Type: SSH_FXP_CLOSE, Size: 23, Number: 10756
Sorry, no idea. Looks like an internal error of the SFTP server. Please contact their support.
khushi
winscp
can any1 help in resolving below error. This error is seen when i am trying to rename binary file also when trying to copy files
Error code: 4
Error message from server: Failure
Request code: 18
Re: winscp
Please start a new thread and attach a complete log file.
davidmartin123
London, UK
Re: winscp
Error code: 4
Request code: 18
If you provide us a SCREENShot then we can help you in a better way...I am a Network Support Guy and will help you.
