WinSCP Denial of Service using sftp:// and scp://
macoo
Is there an update on work for this DoS using the registered URL types?
As work-around remove the keys
HKEY_CLASSES_ROOT\scp
and
HKEY_CLASSES_ROOT\sftp
from your registry.
macoo
Re: WinSCP Denial of Service using sftp:// and scp://
I have not known about this problem. Thanks for pointing my attention to it. I'll fix this in the next version (within about week).
mornauer
problems with winscp3.7.5 beta
With my PC WinSCP works normally.
Recently I have downloaded WinSCP 3.7.5 beta to my notebook with the same implements.
Result: "host does not exist"
What is wrong?
Re: problems with winscp3.7.5 beta
@mornauer: First of all: it seems to me that this has nothing to do with the topic you follow. Am I right?
To your question: It is hard to tell. Can you try to specify IOP address instead of domain/host name?
