Strip UTF8 byte-order-mask on FTP upload (regression)
gpetrioli
Athens, Greece
I believe that there is a re-introduction (or regression) of a previously reported bug.
The initial bug is (bug#888): https://winscp.net/tracker/888 and it is stated that it was fixed for v5.0.8
The version i use is 5.1.4 (build 3020) on Windows 7 Ultimate 64Bit
Not sure if it is an edge case, so i will post some more info
The files i upload have .vbhtml extension (these are asp.net mvc 3 razor view files) and contain html and asp.net razor code (text)
These files lose their BOM (Byte-Order-Mark) char(s) at the beginning of the file. (this causes the browsers to misinterpret their contents)
If i rename the files to .bin and upload them they get transferred fine (obviously as binary) so i understand that the problem occurs with text files.
gpetrioli
Athens, Greece
Ah, ok.
I thought the summary was the bug and not a request (should have paid more attention to the severity)
Thanks for the heads up.
(add one more vote for the implementation of that feature.. )
Linda Kaioh
Hi! I'm using WinSCP beta 5.2.3 build 3436.
When I edit files with internal editor they lose BOM on save (and upload). It's because internal editor use only text mode (I prefer binary for everything).
Can you fix it? ^^'
Can you fix it? ^^'
The Bug 842 is implemented. But if you want to "fix" internal editor to support binary mode, it's unlikely. Use your favorite external editor for this.
Linda Kaioh
Err... Can internal editor (or text mode transfer) preserve BOM?
