WinSCP and Generation Data Group files (GDGs)
devilj
Phoenix
Can WinSCP be used to download the newest file in a Generation Data Group? For instance, I have a set of generated files that look like TST.GGD100.IMAGE.G0001. Each subsequent file is the next in line (..G0002, G0003, n). Normally when you are using FTP on GDGs you would use "GET 'TST.GGD100.IMAGE.G(+1)'.." to download the next file in that set. This isn't working for me in WinSCP.
I am using the code line:
transferResult = session.GetFiles(@"'TST.GGD100.IMAGE.G(+1)'", @"c:\Temp\Image.txt", false, transferOptions);
Does anyone have any ideas on how or even if, WinSCP can do this?
