Save a list of sessions
romanm
is it possible to save a list of sessions?
I have some server who belongs to one project and need to connect to all of them. Now i have to connect to each server manually. It takes a long time when there are 20 server for a project.
Is it possible to connect to all with only one click?
Regards
Roman
Re: Save a list of sessions
Since 5.2 beta you can connect whole stored sessions (sites) folder at once. Actually, It connects the first session only, but sets up tabs for all the others (and connects them as soon as you switch to a tab for a first time).
https://winscp.net/eng/docs/ui_login#management
Moreover you can save your workspace and restore it on the next run.
https://winscp.net/eng/docs/workspace
romanm
Ohh. That's nice.
That's exactly what I was looking for.
I would like it even more if the tabs will be all visible without scrolling.
Thank you
You mean to wrap the tabs over multiple lines?
yes, exactly.
Maybe as a setting.
yes, exactly.
Maybe as a setting.
Ok, will see if more users ask for it.
