SSL3 alert read: fatal: handshake failure
dominion99
I am using 5.1.0 and receive the following error.
It is connecting to a webmethod ftp server, but cannot seem to figure out what is wrong, connection can be set up using ws-ftp-pro, so it must be something related in Winscp.
This is the log file:
. 2013-04-16 10:26:14.202 Session name: FTP@someurl.com (Modified stored session)
. 2013-04-16 10:26:14.202 Host name: someurl.com (Port: 5980)
. 2013-04-16 10:26:14.202 User name: FTP (Password: Yes, Key file: No)
. 2013-04-16 10:26:14.202 Tunnel: No
. 2013-04-16 10:26:14.202 Transfer Protocol: FTP
. 2013-04-16 10:26:14.202 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2013-04-16 10:26:14.202 Proxy: none
. 2013-04-16 10:26:14.202 FTP: FTPS: Explicit SSL; Passive: Yes [Force IP: A]
. 2013-04-16 10:26:14.202 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2013-04-16 10:26:14.202 Cache directory changes: Yes, Permanent: Yes
. 2013-04-16 10:26:14.202 DST mode: 1
. 2013-04-16 10:26:14.202 --------------------------------------------------------------------------
. 2013-04-16 10:26:14.217 Session upkeep
. 2013-04-16 10:26:14.267 Connecting to someurl.com:5980 ...
. 2013-04-16 10:26:14.268 m_pSslLayer changed state from 0 to 1
. 2013-04-16 10:26:14.268 m_pSslLayer changed state from 1 to 2
. 2013-04-16 10:26:14.439 m_pSslLayer changed state from 2 to 4
. 2013-04-16 10:26:14.453 Connected with someurl.com:5980, negotiating SSL connection...
< 2013-04-16 10:26:15.449 220 someurl.com:5980 FTP server (webMethods Integration Server version 7.1.3.0) ready.
> 2013-04-16 10:26:16.443 AUTH SSL
< 2013-04-16 10:26:16.443 234 AUTH SSL OK.
. 2013-04-16 10:26:16.444 SSL3 alert read: fatal: handshake failure
. 2013-04-16 10:26:16.444 SSL_connect: error in SSLv2/v3 read server hello A
. 2013-04-16 10:26:16.444 Can't establish SSL connection
. 2013-04-16 10:26:16.444 m_pSslLayer changed state from 4 to 5
. 2013-04-16 10:26:16.444 Disconnected from server
. 2013-04-16 10:26:16.444 Connection failed.
. 2013-04-16 10:26:16.444 Got reply 1004 to the command 1
* 2013-04-16 10:26:17.318 (EFatal) Connection failed.
* 2013-04-16 10:26:17.318 SSL3 alert read: fatal: handshake failure
* 2013-04-16 10:26:17.318 SSL_connect: error in SSLv2/v3 read server hello A
* 2013-04-16 10:26:17.318 Can't establish SSL connection
* 2013-04-16 10:26:17.318 Disconnected from server
* 2013-04-16 10:26:17.318 Connection failed.
* 2013-04-16 10:26:17.318 AUTH SSL OK.
. 2013-04-16 10:26:27.444 Session upkeep
dominion99
I have tested on the same machine using FileZilla and that is connecting successfully:
Updated the configuration in WinScp to use explicit TLS, here is the new log:
. 2013-04-16 11:12:33.365 Session name: FTP@webbs0071dsm.srvfarm2-eur.dsm-group.com (Modified stored session)
. 2013-04-16 11:12:33.365 Host name: someurl.com (Port: 5980)
. 2013-04-16 11:12:33.365 User name: FTP (Password: Yes, Key file: No)
. 2013-04-16 11:12:33.365 Tunnel: No
. 2013-04-16 11:12:33.365 Transfer Protocol: FTP
. 2013-04-16 11:12:33.365 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2013-04-16 11:12:33.365 Proxy: none
. 2013-04-16 11:12:33.365 FTP: FTPS: Explicit TLS; Passive: Yes [Force IP: A]
. 2013-04-16 11:12:33.365 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2013-04-16 11:12:33.365 Cache directory changes: Yes, Permanent: Yes
. 2013-04-16 11:12:33.365 DST mode: 1; Timezone offset: 0h 0m
. 2013-04-16 11:12:33.365 --------------------------------------------------------------------------
. 2013-04-16 11:12:33.365 Session upkeep
. 2013-04-16 11:12:33.443 Connecting to someurl.com:5980 ...
. 2013-04-16 11:12:33.443 m_pSslLayer changed state from 0 to 1
. 2013-04-16 11:12:33.443 m_pSslLayer changed state from 1 to 2
. 2013-04-16 11:12:33.443 m_pSslLayer changed state from 2 to 4
. 2013-04-16 11:12:33.490 Connected with someurl.com:5980, negotiating SSL connection...
< 2013-04-16 11:12:33.490 220 someurl.com:5980 FTP server (webMethods Integration Server version 7.1.3.0) ready.
> 2013-04-16 11:12:33.490 AUTH TLS
< 2013-04-16 11:12:33.490 234 AUTH TLS OK.
. 2013-04-16 11:12:33.490 SSL3 alert read: fatal: handshake failure
. 2013-04-16 11:12:33.490 SSL_connect: error in SSLv2/v3 read server hello A
. 2013-04-16 11:12:33.490 Can't establish SSL connection
. 2013-04-16 11:12:33.490 Disconnected from server
. 2013-04-16 11:12:33.490 Connection failed.
. 2013-04-16 11:12:33.490 Got reply 1004 to the command 1
* 2013-04-16 11:12:33.553 (EFatal) Connection failed.
* 2013-04-16 11:12:33.553 SSL3 alert read: fatal: handshake failure
* 2013-04-16 11:12:33.553 SSL_connect: error in SSLv2/v3 read server hello A
* 2013-04-16 11:12:33.553 Can't establish SSL connection
* 2013-04-16 11:12:33.553 Disconnected from server
* 2013-04-16 11:12:33.553 Connection failed.
* 2013-04-16 11:12:33.553 AUTH TLS OK.
I will try to fetch a log file from FileZilla, i need this working with WinSCP because i am using another tool that connects via WinScp.
dominion99
Filezilla log file:
2013-04-16 11:18:14 2288 3 Status: Resolving address of someurl.com
2013-04-16 11:18:14 2288 3 Status: Connecting to x.x.x.x:5980...
2013-04-16 11:18:14 2288 3 Status: Connection established, waiting for welcome message...
2013-04-16 11:18:14 2288 3 Trace: CFtpControlSocket::OnReceive()
2013-04-16 11:18:14 2288 3 Response: 220 someurl.com:5980 FTP server (webMethods Integration Server version 7.1.3.0) ready.
2013-04-16 11:18:14 2288 3 Trace: CFtpControlSocket::SendNextCommand()
2013-04-16 11:18:14 2288 3 Command: AUTH TLS
2013-04-16 11:18:14 2288 3 Response: 234 AUTH TLS OK.
2013-04-16 11:18:14 2288 3 Status: Initializing TLS...
2013-04-16 11:18:14 2288 3 Trace: CTlsSocket::Handshake()
2013-04-16 11:18:14 2288 3 Trace: CTlsSocket::ContinueHandshake()
2013-04-16 11:18:14 2288 3 Trace: CTlsSocket::OnSend()
2013-04-16 11:18:14 2288 3 Trace: CTlsSocket::OnRead()
2013-04-16 11:18:15 2288 3 Trace: CTlsSocket::OnRead()
2013-04-16 11:18:15 2288 3 Trace: CTlsSocket::ContinueHandshake()
2013-04-16 11:18:15 2288 3 Trace: TLS Handshake successful
2013-04-16 11:18:15 2288 3 Trace: Cipher: AES-256-CBC, MAC: SHA1
2013-04-16 11:18:15 2288 3 Status: Verifying certificate...
2013-04-16 11:18:15 2288 3 Trace: CFtpControlSocket::SendNextCommand()
2013-04-16 11:18:15 2288 3 Command: USER FTP
2013-04-16 11:18:15 2288 3 Status: TLS/SSL connection established.
2013-04-16 11:18:15 2288 3 Trace: CFtpControlSocket::OnReceive()
2013-04-16 11:18:15 2288 3 Response: 331 Password required for FTP.
2013-04-16 11:18:15 2288 3 Command: PASS ********
2013-04-16 11:18:15 2288 3 Response: 230 User FTP logged in.
2013-04-16 11:18:15 2288 3 Command: SYST
2013-04-16 11:18:15 2288 3 Response: 215 UNIX Type: L8 Version: webMethods IS FTP version 7.1.3.0
2013-04-16 11:18:15 2288 3 Command: FEAT
2013-04-16 11:18:15 2288 3 Response: 500 'FEAT': command not understood.
2013-04-16 11:18:15 2288 3 Status: Server does not support non-ASCII characters.
2013-04-16 11:18:15 2288 3 Command: PBSZ 0
2013-04-16 11:18:15 2288 3 Response: 200 PBSZ Command successful. (PBSZ=0)
2013-04-16 11:18:15 2288 3 Command: PROT P
2013-04-16 11:18:15 2288 3 Response: 200 PROT set to P.
2013-04-16 11:18:15 2288 3 Status: Connected
2013-04-16 11:18:15 2288 3 Trace: CFtpControlSocket::ResetOperation(0)
2013-04-16 11:18:15 2288 3 Trace: CControlSocket::ResetOperation(0)
2013-04-16 11:18:15 2288 3 Trace: CFileZillaEnginePrivate::ResetOperation(0)
2013-04-16 11:18:15 2288 3 Trace: Measured latency of 7 ms
2013-04-16 11:18:15 2288 3 Status: Retrieving directory listing...
2013-04-16 11:18:15 2288 3 Trace: CFtpControlSocket::ChangeDirSend()
2013-04-16 11:18:15 2288 3 Command: PWD
2013-04-16 11:18:15 2288 3 Response: 257 "/" is current directory.
2013-04-16 11:18:15 2288 3 Trace: CFtpControlSocket::ParseSubcommandResult(0)
2013-04-16 11:18:15 2288 3 Trace: CFtpControlSocket::ListSubcommandResult()
2013-04-16 11:18:15 2288 3 Trace: state = 1
2013-04-16 11:18:15 2288 3 Trace: CFtpControlSocket::TransferSend()
2013-04-16 11:18:15 2288 3 Command: TYPE I
2013-04-16 11:18:15 2288 3 Response: 200 Type set to I.
2013-04-16 11:18:15 2288 3 Trace: CFtpControlSocket::TransferParseResponse()
2013-04-16 11:18:15 2288 3 Trace: code = 2
2013-04-16 11:18:15 2288 3 Trace: state = 2
2013-04-16 11:18:15 2288 3 Command: PASV
2013-04-16 11:18:15 2288 3 Response: 227 Entering Passive Mode (144,119,161,81,204,33)
2013-04-16 11:18:15 2288 3 Trace: state = 4
2013-04-16 11:18:15 2288 3 Command: LIST
Hopefully someone can identify if this is a bug or something incorrectly configured within WinSCP, this drives me crazy.
dominion99
I have also used the latest beta 5.2 and imported the site that i have created (and is working in FileZilla) however the same error is thrown, below is that log file from WinScp (now 5.2)
. 2013-04-16 11:30:24.620 Session name: FTP@someurl.com (Stored session)
. 2013-04-16 11:30:24.620 Host name: someurl.com (Port: 5980)
. 2013-04-16 11:30:24.620 User name: FTP (Password: Yes, Key file: No)
. 2013-04-16 11:30:24.620 Tunnel: No
. 2013-04-16 11:30:24.620 Transfer Protocol: FTP
. 2013-04-16 11:30:24.620 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2013-04-16 11:30:24.620 Proxy: none
. 2013-04-16 11:30:24.620 FTP: FTPS: Explicit SSL; Passive: Yes [Force IP: A]; MLSD: A
. 2013-04-16 11:30:24.620 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2013-04-16 11:30:24.620 Cache directory changes: Yes, Permanent: Yes
. 2013-04-16 11:30:24.620 DST mode: 1; Timezone offset: 0h 0m
. 2013-04-16 11:30:24.620 --------------------------------------------------------------------------
. 2013-04-16 11:30:24.698 Connecting to someurl.com:5980 ...
. 2013-04-16 11:30:24.698 m_pSslLayer changed state from 0 to 1
. 2013-04-16 11:30:24.698 m_pSslLayer changed state from 1 to 2
. 2013-04-16 11:30:24.698 m_pSslLayer changed state from 2 to 4
. 2013-04-16 11:30:24.745 Connected with someurl.com:5980, negotiating SSL connection...
< 2013-04-16 11:30:24.745 220 someurl.com:5980 FTP server (webMethods Integration Server version 7.1.3.0) ready.
> 2013-04-16 11:30:24.745 AUTH SSL
< 2013-04-16 11:30:24.745 234 AUTH SSL OK.
. 2013-04-16 11:30:24.854 SSL3 alert read: fatal: handshake failure
. 2013-04-16 11:30:24.854 SSL_connect: error in SSLv2/v3 read server hello A
. 2013-04-16 11:30:24.854 Can't establish SSL connection
. 2013-04-16 11:30:24.854 Disconnected from server
. 2013-04-16 11:30:24.854 Connection failed.
. 2013-04-16 11:30:24.854 Got reply 1004 to the command 1
* 2013-04-16 11:30:24.870 (EFatal) Connection failed.
* 2013-04-16 11:30:24.870 SSL3 alert read: fatal: handshake failure
* 2013-04-16 11:30:24.870 SSL_connect: error in SSLv2/v3 read server hello A
* 2013-04-16 11:30:24.870 Can't establish SSL connection
* 2013-04-16 11:30:24.870 Disconnected from server
* 2013-04-16 11:30:24.870 Connection failed.
* 2013-04-16 11:30:24.870 AUTH SSL OK.
Sorry to post all this log information, but i am hoping someone can shed some light on this
Dominion
Dominion wrote:
I still did not received a debug version, tested the latest beta but the problem still exists, how to proceed?
Seems Martin is ignoring me, another kick for this thread
