Visual glitches in new WinSCP 5.2 beta
Linda Kaioh
Hi! WinSCP 5.2 beta at Windows XP SP3.
Bold gray line at tab bar dosn't look great.
I've found strange white background in file properties dialog. And strange file path label colors:
Same strange colors are in progress dialog:
When I move mouse pointer over path components at inactive panel, they are become same color as background. Previous version doesn't have this glitch.
Path components at active panel have same colors as before but also look awful.
I hope this will help you to make WinCSP look better.
<invalid links removed>
Re: Visual glitches in new WinSCP 5.2 beta
First, thanks for your post.
I'm aware of that. To be honest, it has a low priority as it looks like that only if you have visual themes turned off in Windows.
White background: will take a look.
Path label: Fixed. https://winscp.net/tracker/990
The same. Fixed.
This is taken from your (non-standard theme-less) Windows color settings (Active title bar and Inactive title bar colors).
It do not think there was any change since the last version.
I admit the selection of hottrack color is not ideal (Though still, in most themes, it won't be the same as background color). I'll take a look at this.
Linda Kaioh
No problem ^^
Hmmm... It's strange. I thought previous version use another colors at least for inactive panel. But I was wrong OO
Maybe you just need to use bold font instead of different color?
