Filemask not working on synchronize
MisterDaniel
I am trying to get synchronize to ignore files in the subdirectories (e.g.: "Text Files/Archive/file1.txt"), but it's not working so I'm guessing something is wrong with my code. Could you please advise me? Thanks!
open profile1
option transfer automatic
synchronize local W:\directory1 "Text Files" -filemask="*/"
close
open profile2
synchronize remote W:\directory1 "Files - Inbound" -filemask="*/"
close
Re: Filemask not working on synchronize
Your mask is include mask, what basically means that it does not do anything, as the directories are included by default. To turn it to exclude mask, prepend it with pipe symbol:
synchronize local W:\directory1 "Text Files" -filemask="|*/"
See also https://winscp.net/eng/docs/file_mask
