Synchronize downloads all files, cause by DST?
3K
Geneva
My script below works properly last week but this week, it downloads all the files each time I run it.
- synchronize local c:\mydocs /home/mydocs
I think because of the DST. What will be the script option/command so that it will not download all the files? I've seen synchronize timestamp but couldn't find the right command.
Thank you. :)
Re: Synchronize downloads all files, cause by DST?
Timestamp synchronization is not supported in scripting. You need to do it from GUI.
3K
Geneva
Found this command in the forum and it works:
- winscp.com /rawsettings ConsiderDST=0 /script="myScript.txt"
Then, on myScript.txt, the synchronize command works properly.
So, the solution was to add /rawsettings ConsiderDST=0.
FYI. :D
