how i automatically connet to host
x3group
            this.SessionOptions = new SessionOptions();
            this.SessionOptions.HostName = HostName;
            this.SessionOptions.UserName = UserName;
            this.SessionOptions.PortNumber = PortNumber;
            this.SessionOptions.Password = Password;
            this.SessionOptions.Protocol = Protocol;
            this.SessionOptions.SshHostKeyFingerprint = SshHostKeyFingerprint;
            try
                m_Session.Open(this.SessionOptions);
            catch (Exception exp)
if i set correctly SshHostKeyFingerprint all work
if SshHostKeyFingerprint empty i get exception "SessionOptions.Protocol is Protocol.Sftp or Protocol.Scp, but SessionOptions.HostKey is not set."
but for gui winscp get correctly SshHostKeyFingerprint automatically
Using SSH protocol version 2
We claim version: SSH-2.0-WinSCP_release_5.1.4
Doing Diffie-Hellman group exchange
Doing Diffie-Hellman key exchange with hash SHA-1
Verifying host key rsa2 0x23,0xb9c35c82f30eaaf274a76...
Asking user:
The server's host key was not found in the cache. You have no guarantee that the server is the computer you think it is.
The server's rsa2 key fingerprint is:
ssh-rsa 1024 55:aa:e9:fa:b0:4c:66:e0:ea:cc:4f:34:bf:e2:45:f0
If you trust this host, press Yes. To connect without adding host key to the cache, press No. To abandon the connection press Cancel.
Continue connecting and add host key to the cache? ()
Host key fingerprint is:
Initialised AES-256 SDCTR client->server encryption
Initialised HMAC-SHA1 client->server MAC algorithm
Initialised AES-256 SDCTR server->client encryption
how i get correctly SshHostKeyFingerprint automatically from c# code?
x3group
Re: how i automatically connet to host
Please read FAQ:
https://winscp.net/eng/docs/faq_hostkey
If that does not help, come back.
You should get SSH hostkey fingerprint along with your credentials from the server administrator.
In a real world, most administrators do not provide the hostkey fingerprint.
In order to obtain the fingerprint yourself you need to connect to the server.
how i can run
in c# code?
I connect on 300+ server to periodically download logs
Not sure what you mean.
If you want to give up on any security and just blidlessly connect to any server, you can use SessionOptions.GiveUpSecurityAndAcceptAnySshHostKey. This is available only in 5.2 beta.
