Set transfer mode and file characteristics
moogeboo
I'm trying to connect via SFTP to a site that requires me to set the transfer mode and file characteristics before I upload my file. Basically, i need to issue the following command: ls /+recfm=vb,mode=text,lrecl=27000 before I issue my put command. Is this even possible to do within Winscp scripting?
Thanks,
Mooge
amar
Re: Set transfer mode and file characteristics
Thanks,
Mooge
Did u finf out answer for this. Even i have the same requirement
Did you try my suggestion above?
