Unable to connect to SFTP site
Sven Peeters
I'm struggling to create a connection to an SFTP server.
I've got it working on my local computer (which is directly connected to the internet) but can't get it to connect on our servers.
Firewall on the server is fully off, ping returns external ip of SFTP server and I can open a telnet session on it.
But somewhere just before choosing a key exhange algoritm, it goes south.
I'm not sure what to ask our netwerk guy because he will say that port 21 is open.
WinSCP Version 5.1.4 (Build 3020) (OS 6.1.7601 Service Pack 1) - windows Server 2008 R2 standard SP1
The top log is from the server, the bottom one from my local machine.
All events preceding this are identical (except socket number).
Full logs are included as attachement.
Any idea's?
Regards,
Sven Peeters
. 2013-03-26 08:48:57.823 Enumerating network events for socket 1192
. 2013-03-26 08:48:57.823 Enumerated 32 network events making 32 cumulative events for socket 1192
. 2013-03-26 08:48:57.823 Handling network close event on socket 1192 with error 10053
. 2013-03-26 08:48:57.823 Selecting events 0 for socket 1192
. 2013-03-26 08:48:57.823 Network error: Software caused connection abort
* 2013-03-26 08:48:57.885 (EFatal) Network error: Software caused connection abort
. 2013-03-26 08:57:48.994 Enumerating network events for socket 1016
. 2013-03-26 08:57:48.994 Enumerated 1 network events making 1 cumulative events for socket 1016
. 2013-03-26 08:57:48.994 Handling network read event on socket 1016 with error 0
. 2013-03-26 08:57:48.994 Using Diffie-Hellman with standard group "group1"
. 2013-03-26 08:57:48.994 Doing Diffie-Hellman key exchange with hash SHA-1
Description: Log file
Re: Unable to connect to SFTP site
Are you able to connect using any other SSH client?
Also note that SSH server should be running on port 22. Port 21 is for FTP. Though that could be an issue only in case there's some proxy/firewall/anything on the way, trying to interpret the connection as FTP.
