Cannot download using sftp
roshan
Hi:
I want to download file automatically.I saved this script in .txt file and call the .txt file in command prompt:-
option batch abort
# Connect
open "CDN" -hostkey="ssh-rsa 1024 fe:8f:d9:c0:5b:a4:f8:bf:91:4f:80:41:36:7b:38:87"
# Change remote directory
cd /home/user
# Force binary mode transfer
option transfer binary
# Download file to the local directory d:\
get test.txt c:\
# Disconnect
close
# Exit WinSCP
I can see that it is connecting but it doesnt copy file to c:\.Any idea where is the problem
Re: Cannot download using sftp
roshan
Hi :
I fixed it. But when i run the command it copies folder and subfolders.How can i just copy the file and not folder and subfolder structure. .The command is below:-
get -filemask=FULL_us_chhc_*2013*.txt /pc/user1/backup/backup/backup/* c:\
Regards,
Roshan
You cannot.
ok.Is there any way i can copy the file if it exists in any subfolder.What i am trying to do is user will enter file name and it needs to be copied to local server .The file can reside in any folder/subfolder
