command line operation question (short)
mike
I have successfully used the command line option to /upload files to the host. Only question is how do you make winscp3 stop asking me questions-- I have checked the box that says use same format next time several times now. Please help.
I need to run this in a script.
Mike
Re: command line operation question (short)
/upload switch is inteded to supports Windows Explorer "send to" menu only. It is not intended for scripting. You may not switch off the dialog.
Scripting support is on the wishlist already. Meanwhile I recommend you to use PSFTP tool (freeware command line SFTP client).
