Error getting name of current remote directory
zeus_12345
1.0/
winscp commandline:
Searching for host...
Host does not exist
winscp> open ftp://anonymous:123@163.160.160.22:21
Connecting to 163.160.160.22 ...
Connected with 163.160.160.22. Waiting for welcome message...
Connected
Starting the session...
1.0/
1.0/
winscp>
windows ftp:
D:\Documents and Settings\a30725.GBR>ftp 163.1600.160.22
Unknown host 163.1600.160.22.
ftp> open 163.160.160.22
Connected to 163.160.160.22.
220 163.160.160.22 System Card FTP server (0.22_ Release) ready.
User (163.160.160.22:(none)): anonymous
331 Guest login ok, send password.
Password:
230 Guest login ok, access restrictions apply.
ftp> pwd
550 1.0/
ftp> ls
200 PORT command successful.
150 Opening ASCII mode data connection for ..
imc.ini
TEST.DAT
ni.dat
HIST.TXT
Is there a method to connect to this system?
Thank you for help.
Best regards
Re: Error getting name of current remote directory
Sorry, I should have noticed this already in your initial post. Your server responds with error code 550 to PWD request. WinSCP cannot deal with that. It needs to know what is your current working directory to allow navigation. It's actually not strictly needed for command-line interface. But WinSCP is primarily GUI client.
zeus_12345
Hi Martin,
here a log of MS ftp
D:\Documents and Settings\xxxxx.GBR>ftp 163.160.160.22
500 'USER ': command not understood.
Login failed.
ftp> user ftp
Password:
ftp> pwd
550 1.0/
ftp> dir
-rwxrwxrwx   1 root      1024 Apr 02 2013 00:00 TEST.DAT
226 Transfer complete.
ftp: 991 bytes received in 1.69Seconds 0.59Kbytes/sec.
ftp> mkdir gst
257 MKD command successful.
ftp> cd gst
250 CWD command successful.
ftp> pwd
550 1.0/gst
ftp> bye
221 Goodbye.
it seems, that 550 is no an error, but a part of the directory
have you an idea how to move around this issue
best Regards
günter
