After copying files to the server they have a different time
Dirki
When I copy / sync files with (local with server) the copied files on the server have a time difference of an hour earlier, so will be always synced. How could I correct it?
_________________
My System: updated XP, newest Service Pack
WinSCP: newest version, GUI (Commander Interface, Norton Commander), Transfer protocol: FTP
Re: After copying files to the server they have a different time
Please attach a full log file showing repeated synchronization of a single file (if possible).
