Using a wildcard with an Upload
woodard
I am trying to use a wildcard with an Upload but I'm getting an error that the file can't be found. Is this only available with the Put?
Re: Using a wildcard with an Upload
Sorry, no idea what you mean. Can you post an example? Or even better a session log file.
