Subfolders not sync
ck80
Subfolders not sync
Using WinSCP for synchronizing folders with docs. In folders there is a lot of subfolders with files:
Documents
----\Instruction
------\program1
---------\file1.doc
---------\file2.pdf
-------\other instruction
---------\file1.pdf
----\Common docs
When using command line, synchronizing not appear. Manual sync is working. Trying to use other switch: "local" "remote" "mirror" with no luck.
Using command: "C:\Program Files\WinSCP\WinSCP.exe" ftp@ServerIP /console /command "option include "*.db"" "option include "recycle"" "synchronize local -delete D:\Documents\ /documents/" "exit"
Winscp ver.5.1.2 on Windows Server 2003.
Source directory is ubuntu Server. Permission on files is 777
Re: Subfolders not sync
ck80
Russia
Sorry, my mistake.
Wrong usage "option include "*.db"" "option include "recycle""
I thought this option exlude those mask files from synchronisation.
