WinSCP file to multiple servers / hosts
ananyboss
I want to send a small file to 100–500 servers,
I am currently doing a WinSCP to each server, input username password every time!
Is there any way to automate it?
Re: Winscp file to multiple servers / hosts
Scripting:
https://winscp.net/eng/docs/scripting
You can upload the file with single line like:
winscp.com /command "open sftp://username@hostname/" "put c:\localfile /remotepath" "exit"
Just copy and paste this to a .bat file as many times as you need and just make sure you have correct hostname on every line.
alex96
upload at once to multiple servers
hi Martin,
I try to do it as you wrote below, but unfortunately not succeeded it, so obviously I am doing something wrong.
Please help me with a concrete example, using following datas:
server1: myserver1.com username: username1@myserver1.com password: passw1 folder: root/folder1
server2: myserver2.com username: username2@myserver2.com password: passw2 folder: root/folder2
server3: myserver3.com username: username3@myserver3.com password: passw3 folder: root/folder3
page to be uploaded: C:\folder\example.html
thank you very much in advance.
Alex
Jagadeesh
Re: upload at once to multiple servers
I am unable to resolve the user name & password issues.
I am trying to copy a file from my windows local machine remote linux machine which can be connected with a user name & pwd.
I have a batch file as below.
cd\
cd C:\Users\E002856\AppData\Local\WinSCP
WinSCP.com /script=C:\Users\E002856\ScrToCpFilesToMultLoc.txt
ScrToCpFilesToMultLoc.txt is the script file whose code is as below.
open sftp://username:password@172.16.3.30/
put d:\examplefile1.txt /home/test-user/temp/
When I try to execute the batch file, it's asking me to provide the username & pwd again where I provided in the script already.
I can able to execute this code manually with no issue.
Any ideas how to resolve this.
Thanks in Advance.
@Jagadeesh: Please start anew thread and attach a full session log file showing the problem (using the latest version of WinSCP).
