Help with Windows Server 2008 Scheduled Task
wongnation
OK, I'm probably missing something obvious, but I am having difficulty getting a Windows 2008 Server Scheduled Task to execute WinScp.com correctly.
The task is configured to run with the highest privileges and as a specific user account. The command runs fine when I log in as that user account and run the task manually. (The user account is also a domain admin). I have also selected the "Run whether user is logged in or not" option. The "Start in (optional)" field is also set to the WinScp directory (C:\Program Files (x86)\WinSCP).
However, when I select "Run" to trigger the scheduled task to execute, it seems to run indefinitely.
From viewing the Task Manager, I can see the winscp.com and winscp.exe processes start up, but they never end (until I manually end the task or kill the processes).
For sanity's sake, I tried modifying the scheduled task to something simple:
winscp.com /log=foo.log /command "exit"
where the arguments are specified in the "Add arguments (optional)" dialog and even this seems to hang when run as a scheduled task. But this runs fine when I execute it from the Windows command line.
One thing is that the Windows Task Scheduler service is configured to run as the Local System, but I assumed that the specified user account would override that. Also, no log file is generated, but since I am not even connecting to a host, that's somewhat expected.
Again, I apologize in advance if I've missed something obvious, but was wondering if anyone else had run into this. I am running v5.1.4.
Re: Help with Windows Server 2008 Scheduled Task
The above command should definitely never hang.
Difranev
Exactly the same issue with winscp via scheduled task
what was wrong? did you find anything? I have exactly the same issue and it's driving me nuts.
Working correctly when i launch the script manually but winscp.exe and winscp.com are hanging in the task manager and do nothing when launch by scheduled task
Please help :'((
Eve.
Re: Exactly the same issue with winscp via scheduled task
Did you read FAQ?
https://winscp.net/eng/docs/faq_scheduler
trefrog
fixed this for myself
My problem was that WinSCP.exe wasn't exiting when I ended the task via the Task Scheduler, so my first two test runs were actually still running in the background, and downloading humungous things that I was trying to exclude...
provided that your ini settings, script, and task options are all in order... as per the FAQ.
all I had to do was use WinSCP.com instead of ".exe /console". That's it. That change alone fixed the problem!
Re: fixed this for myself
Do you mean that you ended winscp.com process and a winscp.exe process was not terminated along? That should not be happening, unless you use some ancient version of WinSCP (4.1.3 or older) or Windows (2000 or older).
See https://winscp.net/tracker/246
