Too many parameters for command open
SRK
" Error : Too many parameters for command open "
I am trying to transfer the files using SFTP with Pair Key authorization: Please find the below script as similar to my original script
option batch on
open sftp://<UserName>@<Server> -privatekey=<Private Key>.ppk
I am currently using WinSCP 4.2.8.818(Size: 6.06 MB), I have also read the https://winscp.net/eng/docs/faq_script_switch but didn't find any solution.
Your suggestions/advice will really help us.
Thanks in advance.
SRK
Achmad
too many parameters for command "open"
I got the same message when run command as below:
open -explicittls -passive=on ftps://username:passwprd@foo.com:50021 -rawsettings ProxyMethod=3 ProxyHost=proxy.net ProxyPort=8080 ProxyUsername=itdept ProxyPassword=testonly
Please advise.
Achmad
Re: too many parameters for command "open"
What version of WnSCP are you using? Make sure you have the latest one.
