Error uploading file
I am trying to use VBA in Excel 2010 to upload a file to my SFTP server. When I use WinSCP.exe, the file uploads, but only after a message saying "Upload of the file <FileName> was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on "ignore permission errors" option."
When I try to upload using VBA, I get error number 2146233088, "Cannot create remote file <filename>". I have tried a filepermissions object and setting Otherwrite, Userwrite, and Groupwrite all to True, but it makes no difference:
As soon as transferResult.Check runs, it throws the error. What am I doing wrong?
mySession.Open mySessionOptions Dim myFilePermissions As New FilePermissions myFilePermissions.OtherWrite = True myFilePermissions.UserWrite = True myFilePermissions.GroupWrite = True Dim myTransferOptions As New TransferOptions myTransferOptions.TransferMode = TransferMode.TransferMode_Binary myTransferOptions.preservetimestamp = False myTransferOptions.FilePermissions = myFilePermissions Dim transferResult As TransferOperationResult Set transferResult = mySession.PutFiles("D:\temp\ADBCopy.bat", "/Distribution/FTFZI/PILOT/*.*", False, myTransferOptions) ' Throw on any error transferResult.Check
