All files selected
All files selected
After establishing the connection all files in both panels are selected. It seems to be some problem with windows configuration because using another winscp3.ini file from twin PC where everything is alright nothing changed.
What's the hell going on with this windows???
Thank you in advance for any suggestions.
Wojtas
Re: All files selected
I have never heard about such problem. What version of Windows do you use? If you find what causes this, please let me know.
