Timeout setting has no effect
Hello there! I'm using winscp 5.1.3 on windows XP and the timeout setting (gui) doesn't work. If i set it to 120 forinstance, it gives me the reconnect windows after 15 sec.
Do you have any solution fpr that?
best regards
Klaus
Re: Timeout setting has no effect
