v.5.1.4 ERRORLEVEL is equal to 0 after authentication failed
kosmo
Hi!
I'm running portable version of 5.1.4 on Win 2000 SP4 x86 machine and getting %ERRORLEVEL% equal to 0 if authentication for protocol FTP fails
I'm analyzing this variable and depending on its value deleting files prepared for transfer.
batch file
set ftp_user=u
set ftp_pass=p
set ftp_host=ftp.example.com
set source_mask=C:\Temp\*.txt
winscp.com /script=script.txt /log=winscp.log
echo Error: %ERRORLEVEL%
script file
option batch abort
open ftp://%ftp_user%:%ftp_pass%@%ftp_host%
option transfer binary
put "%source_mask%"
close
shows me
batch           abort
confirm         off
Connecting to ftp.example.com ...
Connected with ftp.example.com. Waiting for welcome message...
Access denied.
Authentication failed.
Error: 0
log's tail
< 2013-03-04 16:57:09.188 331 Password required for u
> 2013-03-04 16:57:09.188 PASS *
< 2013-03-04 16:57:09.204 530 Login incorrect
. 2013-03-04 16:57:09.204 Connection failed.
. 2013-03-04 16:57:09.204 Password prompt (last login attempt failed)
Re: v.5.1.4 ERRORLEVEL is equal to 0 after authentication failed
Please attach a full log file showing the problem.
kosmo
Cleared out: my mistake
Hi Martin,
sorry, found out the reason in full version of script!
Short answer: need to use delayed expansion, if you are in statements group
Long answer: after examining my original script
@echo off
set ftp_host=localhost
set ftp_user=u
set ftp_pass=p
set source_folder=C:\Temp
set source_pattern=*.txt
set winscp_root=winscp
set source_mask=%source_folder%\%source_pattern%
setlocal
if exist "%source_mask%" (
   "%winscp_root%\winscp.com" /script=PutFiles.ftp > "%TEMP%\winscp.out"
   if %ERRORLEVEL% EQU 0 (
      echo Success
   ) else (
      echo Problem while copying files
) else (
   echo No files to upload
endlocal
I've found out that all assignments in if exist "%source_mask%" ( ... ) block are not actual within the same block.
So I changed my piece of code in the following way:
@echo off
set ftp_user=u
set ftp_pass=p
setlocal enabledelayedexpansion
   if !ERRORLEVEL! EQU 0 (
      echo Success
   ) else (
) else (
endlocal
and it worked! Sorry for disturbing...
