keepuptodate -- workaround for time zone differences?
tuno
Goodyear, AZ USA
I'm using 5.1.4 on Windows 7 64-bit. I'm a new WinSCP user and my interest is in using WinSCP's automatic "keepuptodate" feature.
I have not been able to get it to work for me, and I'm fairly certain that the reason is the 2 hour time difference between my local computer and the server -- 2 hours have to elapse before WinSCP detects that the server's files are older than modified counterparts in the local folder.
Has anyone found a workaround for this? I suppose I could set my local computer's time to that of the server's, but that would not be my first choice.
Advance thanks
ted in AZ, USA
ps ... great product!!!
Re: keepuptodate -- workaround for time zone differences?
