Automation using Bat/Script via Window server 2012 Scheduler
cunning
I have used INI method in WINSCP..
When i try to manually run the batch file where Pageant is on system tray. Connection is fine. it does not ask me any password or phrase.
But when i try to run it via Task Scheduler it does not check pageant and ask me for password. DO you have any idea about it please let me know!
cunning
Re: Automation using Bat/Script via Window server 2012 Scheduler
I don't think it solves the issue. My question is why it does authenticate with Pageant when i run Batch file manually but not from windows Scheduler??
Have anybody tried it?
Because the pageant needs to run in the same Windows session as WinSCP. Pageant is really not intended for automation.
cunning
Actually it was Pass Phrase issue on Privatekey. Is is possible to pass through phrase in script file?
I have to remove Pass phrase to resolve the issue!
This request is being tracked already:
https://winscp.net/tracker/816
miro_ilias
I have the same problem - Windows 7 scheduler can not authenticate with Pageant, only from batch file manually.
Re: Same Issue...
jdantzler wrote:
I am having the same issue. It would be great if we can come up with a solution to this problem.
Solution is in my very first response above.
jwd41190
Re: Same Issue...
Still does not work even without a passphrase...Thanks
Re: Same Issue...
